Transmission will not go into gear after replacing the solenoid?
1999 SATURN SL1
171,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
DSANFORD
Replaced solenoid by removing valve body, now it won't go into gear at all, then I realized the rod wasn't hooked to the cylinder, hooked it up and it still won't go into gear... Do I have it in the right hole?
Jul 16, 2023 at 1:21 AM
  • 110,244 POSTS
I need a little info. What solenoid was replaced? Also, which rod are you referring to?
As far as solenoid actuators, there are five. The five actuators are the:
- Pressure control solenoid
- Torque Converter Clutch (TCC) solenoid
- 2nd/reverse clutch solenoid
- 3rd clutch solenoid
- 4th clutch solenoid
I need to know which was replaced and what rod you attached.
Jul 16, 2023 at 1:41 PM
