transmission
216,500 MILES
JWOLF41
  • 6 POSTS
99 acura cl 3.0 had no 2nd gear. Replaced 2nd gear clutch pressure switch no fix,rebuilt ttransmission.. clutches in 2nd gear drum were gone. Replaced clutches , vehicle will drive great except no change. No 2nd gear. Pull the gear selector to any gear and drive. Pull it right into 2nd and within 20 seconds it releases 2nd gear. Checked shift solenoid b and c all appears fine ohms at 15.9 and here clicking when power to solenoid...what could be causing this...
Apr 17, 2013 at 4:45 AM
DOCFIXIT
  • 18,828 POSTS
During all this work was PCM checked for trans codes?
Apr 17, 2013 at 5:00 AM
JWOLF41
  • 6 POSTS
Yes before I started.
P1738-2nd gear clutch pressure switch
P1739 3rd gear. ". ". "
P1740 4th gear. ". ". "
P0730- shift malfunction B
* shift solenoid A or D stuck Off
* shift solenoid B stuck on shift valves A/B/D stuck
From park to 1,3, or 4 trans holds firm.. go from park to 2 and it holds for 5 seconds.
Go down highway skip second into 3rd car runs great...
Apr 17, 2013 at 5:17 AM
DOCFIXIT
  • 18,828 POSTS
Was wiring from solenoids to PCM OHM checked? Where codes cleared ? and what is present now?
Apr 17, 2013 at 5:30 AM
JWOLF41
  • 6 POSTS
I did not check wires off solenoids.( not sure what the ihms range is)
Codes were all cleared... no codes present at this time
Apr 17, 2013 at 5:35 AM
DOCFIXIT
  • 18,828 POSTS
You would OHMS to verify contiuity if good then suspect fault in PCM not switching solenoid for second gear
Apr 17, 2013 at 5:39 AM
JWOLF41
  • 6 POSTS
I tried ohms to check continuity. I believe I have it...what else would cause 2nd gear to engage and then release?
Apr 17, 2013 at 6:35 AM
DOCFIXIT
  • 18,828 POSTS
So what happened?
Jun 4, 2013 at 1:48 AM
