transmission
189,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
JESSE BARBER
truck moves only a couple inches in any gear giving a lot of gas. Was driving up a hill and lost high gear, then after stopped , would not move much. fluids are full. Is this the transmission or something else?
Mar 30, 2017 at 11:05 PM
HMAC300
  • 48,601 POSTS
sounds more like the transmission has a clutch pak or seal bad. have a transmission professional look at it. unless drive shaft is spinning when you put in gear.
Mar 31, 2017 at 12:14 AM
JESSE BARBER
Thanks for response. I was looking to save by not having to take to garage.
Mar 31, 2017 at 3:13 AM
HMAC300
  • 48,601 POSTS
everybody does nothing wrong with it, but a lot of times you need it looked at by a professional.
Mar 31, 2017 at 3:26 AM
