Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Windstar
Drivetrain
Transmission
Gear Position Sensor
Replace/Remove
Van will not move after replacing neutral safety switch
2002 FORD WINDSTAR
160,000 MILES • 0.5L • 6 CYL • 2WD • AUTOMATIC
GEORGIAPORGIE
MEMBER
1 POST
Put new neutral safety switch in now van wont move. Can't even push it wheels will not move.
Oct 28, 2019 at 12:42 AM
Experienced Mechanic
Since your vehicle is an automatic it has what is called a transmission range sensor. When you installed this did you use an alignment tool?
Here is the procedure for replacing this. Let me know if you need more info but if this is not aligned properly then this issue can happen.
Images (Click to enlarge)
Oct 28, 2019 at 11:50 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
