When changing different which fluid do I use
200,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
KEVNLKING
  • 26 POSTS
I have a three speed automatic transmission. When changing the differential fluid do I use gear oil or do I use transmission fluid?
Aug 19, 2018 at 6:21 PM
Good morning.
It takes ATF.
Recommended ATF is Dexron II or Dexron III.
Aug 19, 2018 at 8:46 PM
KEVNLKING
  • 26 POSTS
Do I use gear oil or transmission fluid for the transmission gearbox on the rear of the transmission?
Aug 20, 2018 at 6:20 AM
As listed above, it takes the same fluid.
Use Dexron 2 or 3.
Aug 20, 2018 at 6:23 AM
