Transmission swap
20,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
MEGMA16
Can i replace my 2004 transmission with a 2005 transmission?
Jan 26, 2018 at 2:21 AM
  • 31,937 POSTS
Both models use the same transmission the 5R55s. so there should not be a problem but i would contact a transmission specialist or Ford just to make sure that there is no TCM re-flash required to suit the individual transmission to be fitted. Later transmissions have strategies to be re loaded, not 100% sure if the older transmissions will require this as well.
Jan 26, 2018 at 12:40 PM
