Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Elantra
Drivetrain
Transmission
Symptoms
Not Shifting
Transmission not shifting into gear
2002 HYUNDAI ELANTRA
236,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
JACKSONBROWN
MEMBER
1 POST
Will not shift into gear.
Jan 1, 2019 at 8:50 AM
Experienced Mechanic
Good morning,
Did you check the fluid feel?
Does the shifter feel the same as it always has? if there is an issue with the cable, it would seem loose or not normal.
How long since the fluid and filter was changed?
Jan 1, 2019 at 8:24 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
