Transmission slow or delayed shift
230,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
WENDYKRISMAN
When driving the transmission either slips or has a slow or delayed shift going from first to second. Also it makes a clunking noise when put in reverse but then goes fine in reverse.
Aug 6, 2018 at 5:20 PM
  • 55,808 POSTS
It sounds like the fluid is low and the unit needs to be serviced. Here is a guide to give you an idea on what to do. Also we should run the codes as well.
and
Cheers, Ken
Aug 8, 2018 at 5:31 AM
