Transmission TCS light on
168,000 MILES • AUTOMATIC
ANGEL_REYNA
Hi, the TCS light came on and it does not run at all. what could it be? when is cool in the morning I turn it on and it will run like one mile then it starts to not shift gears.
Mar 29, 2018 at 12:40 AM
KHLOW2008
  • 41,812 POSTS
When an indicator light turns on, it means a fault in the system has been detected. For rectification, we need to understand which section of the system is faulty and a diagnostics scan would allow you to retrieve the trouble codes stored in the system.
I would suggest you get a scan done and post the trouble codes here so we can understand and provide the necessary recommendations.
Mar 29, 2018 at 4:13 PM
