Transmission not shifting properly
120,000 MILES • V8 • 2WD • AUTOMATIC
BRETT SLATER
It is as if the transmission jumps out of gear into neutral then once the rev comes back down goes back into gear. Throws a check engine code. once cleared will begin to shift again for different amounts of time so before starting over again!
Aug 19, 2019 at 2:54 PM
Good morning,
Do you know the code for the check engine light? Clearing a code does nothing as the issue needs to be addressed.
How long since you change the fluid and filter?
Aug 19, 2019 at 8:49 PM
