I cannot get in to neutral all gears work
254,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
LONNIE SEHER
Replace transmission shifter back in all linkage are lined up but i cannot get in to neutral all gears work, but will not hit neutral.
Apr 20, 2017 at 6:54 AM
HMAC300
  • 48,601 POSTS
you will have to pull transmission and remove shift cover to see if shift forks are lining up after putting in neutral if linkages are okay and everything lines up. if not it may be a bent shift fork, etc.
May 4, 2021 at 2:44 AM
