Transmission swap
159 MILES • 3.4L • V6 • AUTOMATIC
SPARKLE SHINE
What other transmission can I put in the vehicle listed above?
May 29, 2022 at 1:49 PM
  • 110,248 POSTS
Because of "technology", you can only use the same type. I'm not sure if you have a 4wd model or 2wd model vehicle. If it is a 2wd, the transmission model is a
55-50SN. It was used by different manufacturers, but the problem is they are customized as far as sensors to the vehicle's control module.
If it is 4wd, it has an AF33-5 automatic transaxle. Basically, the same principles apply.
I attached a pic below showing how to identify the transmission type just for confirmation.
Let me know what is happening. Maybe the transmission can be repaired.
See pic below.
May 29, 2022 at 2:57 PM
