Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercedes Benz
C230
Drivetrain
Transmission
transmission
2004 MERCEDES BENZ C230
120,000 MILES • 2.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
JIMMO
MEMBER
1 POST
The car does not run, transmission problem.
Sep 5, 2017 at 6:37 AM
Experienced Mechanic
A transmission problem on this car is a job for a specialist, you cannot even do an oil change with out special equipment. if it will not drive you will have to get it towed to a transmission specialist or a dealer to start the diagnosis procedure.
Sep 5, 2017 at 9:23 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
