vehicle needs to have the transmission replaced
189,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
MELANIE74
My vehicle needs to have the transmission replaced. do I need to drop my transmission
Oct 17, 2017 at 7:00 AM
STEVE W.
  • 15,408 POSTS
This video shows the job being done on a similar car but the process is the same. step by step with instructions in the diagrams below to show you how on your car.
https://youtu.be/3vJAojsrfuU
Oct 17, 2017 at 8:20 AM
MELANIE74
I have to replace the whole coolant line, and cannot get the end that is attached to the transmission off.
Oct 18, 2017 at 5:56 AM
STEVE W.
  • 15,408 POSTS
Those are push connect fittings, you slip the tool down over the line and they should pull free. Then you sort of pull the line down and out. Make sure you have the front out first as the line needs to twist a bit for it to come out.
Oct 18, 2017 at 7:13 AM
MELANIE74
Okay got it. Thanks
Oct 19, 2017 at 5:51 AM
