Transmission not shifting properly
200,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
MATEO LIBONATI
the box truck runs fine but the transmission will not auto shift on it own; once I stop I must manually place auto lever in lowest gear then manually shift it up to next higher gear to make transmission achieve higher gears.
is there a module of some type that's gone bad or is transmission on its way out?
thanks
Mar 13, 2021 at 3:01 AM
  • 110,248 POSTS
It could be an internal issue. However, if you can shift it manually, the clutches sound fine. The first thing I would check is the transmission fluid. Check to make sure it is full and its condition.
Also, I am not showing this vehicle as a "truck". What model is it? Was the transmission fluid ever changed?
Take care and God Bless,
Mar 15, 2021 at 11:20 AM
