After making a loud noise while driving transmission will not engage in gear
203,421 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JOEY267
Made a loud screech while going down the road now wont engage in any gear.
May 7, 2020 at 1:55 AM
STEVE W.
  • 15,421 POSTS
A loud screech and now no movement suggests an internal transmission failure. When you put it into gear do you hear anything like a rattle or clunk? That may suggest that the failure was in the torque converter. If there is no engagement at all, IE you put it in gear and nothing happens, no change in the engine rpm or even a hint of motion then it is more likely a hard part failure like a pump or clutch failure. For those the transmission would need to be torn down to find the problem. The only saving grace is that being a 2WD it is easier to remove than the 4X4 version.
Things to check before condemning the transmission are few, the basic one would be to have someone hold the brakes with the truck in gear and make sure that the driveshaft isn't turning. While very rare this would make sure it wasn't a failure in the rear end, like a pinion or ring gear failure. Very doubtful but it's possible.
May 7, 2020 at 2:17 AM
JOEY267
No rattle or clank no jump no indication that it's trying other than a very very slight jump in rpm that lasts for maybe half a second and then it returns to normal. i thought about putting in a new torque converter that was the first thing that came to mind after it happened just because of how it screeched. it was just once similar to how a belt or pulley might screech but much louder i figured if it were a gear or bearing it would have made a lot more commotion than just a singular screech. Also tried holding the brake while putting it in drive and there was no movement in the driveshaft. so that's a plus i suppose.
May 7, 2020 at 2:48 AM
STEVE W.
  • 15,421 POSTS
I've had transmissions fail internally with no sounds at all, just poof, no go. Usually that is something like a sheared band or failed seals. The loud sounds are commonly metal on metal contact or parts failure. Pull the dipstick and wipe it off on a piece of clean white paper, look for any glitter that would show metal damage. You might even want to drop the pan to check it for anything that came apart or ground itself up.
May 7, 2020 at 8:05 AM
JOEY267
I checked the dipstick for any metal flakes i didn't see any. I'm going to drop the pan tomorrow and see if by any stroke of luck i can see if something is in it that might give an indication of what failed. if not i will probably go ahead and put in a new torque converter and hope for the best. If that's not the culprit then the fun part begins. I appropriate the feedback.
May 7, 2020 at 10:23 AM
STEVE W.
  • 15,421 POSTS
If you don't see any metal in the pan it likely isn't the converter, Normally they leave some metal in the fluid if they chew themselves up same with the front pump. You could try running a pressure test on it to see if the pump is turning and if any of them respond when you shift it. Zero pressure would mean the pump isn't turning low would point at internal leakage.
May 7, 2020 at 10:44 AM
