Speedometer is not working
75,000 MILES • 8.1L • V8 • 2WD • MANUAL
BOBBY BOOSHEA
Was needing to know about the sensors on the side of the transmission. i have one on each side of it .
Feb 9, 2019 at 2:30 AM
Good afternoon,
The most common cause is the vehicle speed sensor.
Do you have an Allision transmission? The 8.1 offered this option.
Feb 9, 2019 at 4:50 AM
Hello again,
I found this diagram for you.
Check it and see if you have this sensor at the rear of the transmission?
Feb 9, 2019 at 4:53 AM
