Transmission not shifting properly after replacing engine
100,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
FOXDEN
  • 22 POSTS
Changed out engine in car. Went for drive on open road. Got up to around 60 with cruise and OD on, on hill transmission acted like it had gone into neutral. Stopped put car in park then drive with OD off. car ran back home. Next morning put car in reverse and it did not engage. did not have a problem when motor went out. Car has sat for two years before engine exchange. Also lost the odometer speedometer still works. Could it possibly be electrical? How can I trouble shoot the transmission and odometer.
Sep 20, 2019 at 6:09 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Since you replaced the engine, I feel confident that you checked the basics such as fluid level, fluid leaks, and so on. What needs to be done is to have the computer scanned to see if there are diagnostic trouble codes related to the transmission. That will point us in the right directions for repairs.
As far as the odometer, it works in conjunction with the speedometer. Does it turn on and not change the mileage or doesn't it work at all?
Also, make sure the transmission position switch (range sensor) is still properly connected and not damaged. I attached a pic of it.
When you remove the engine, a lot of wiring was moved around, so make sure there were no grounds or sensors left unplugged. Also, make sure the shift linkage is properly installed and moving the shift lever at the transmission.
Let me know what you find.
Sep 21, 2019 at 1:02 PM
FOXDEN
  • 22 POSTS
Hi Joe,
Well the speedometer and odometer are good. I was just looking at the wrong spot for the odometer.
The range sensor is connected and I see no apparent damage. the code that cam up is PO500. Speed sensor.
Foxden (Jerry)
Sep 22, 2019 at 6:08 AM
  • 110,248 POSTS
Welcome back:
A speed sensor can cause shifting problems. The location of the sensor is on the bell housing near where it mounts to the engine. It is easy to damage a wire, pinch a wire or even partially disconnect the connector.
Do me a favor. Check to see if any of the aforementioned conditions exist. Here are the directions for replacing the sensor. At least these directions will get you to the right part so you can check. The attached pics correlate with the directions.
I have to be honest, I'm not sure how it could have caused the vehicle to go to reverse. However, since the code exists, something has happened, so lets start there.
____________________________________________
2000 Toyota Celica GT L4-1.8L (1ZZ-FE)
Removal and Installation
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Vehicle Speed Sensor Service and Repair Procedures Removal and Installation
REMOVAL AND INSTALLATION
ON-VEHICLE REPAIR
1. REMOVE BATTERY
2. REMOVE ECM AND ECM CASE
3. REMOVE ECM BRACKET
pic 1
4. DISCONNECT VEHICLE SPEED SENSOR CONNECTOR
5. REMOVE VEHICLE SPEED SENSOR ASSEMBLY
a) Remove the bolt and vehicle speed sensor assembly.
b) Remove the clip and speedometer driven gear from the vehicle speed sensor.
c) Remove the O-ring from the vehicle speed sensor.
pic 2
6. INSTALL VEHICLE SPEED SENSOR ASSEMBLY
a) Coat a new O-ring with ATF and install it to the vehicle speed sensor.
b) Install the speedometer driven gear to the vehicle speed sensor with clip.
c) Install the vehicle speed sensor assembly with the bolt.
Torque: 5.5 Nm (56 kgf-cm, 49 inch lbs.)
7. CONNECT VEHICLE SPEED SENSOR CONNECTOR
8. INSTALL ECM BRACKET
Torque:
Bolt: 18 Nm (185 kgf-cm, 13 ft. lbs.)
Nut: 12 Nm (120 kgf-cm, 9 ft. lbs.)
9. INSTALL ECM AND ECM CASE
Torque: 6.9 Nm (70 kgf-cm, 61 inch lbs.)
10. INSTALL BATTERY
Sep 22, 2019 at 9:51 AM
FOXDEN
  • 22 POSTS
I will check speed sensor today.
I believe there was miscommunication, probably in my description the vehicle problem, the vehicle did not go to reverse, but there is no reverse at all.
Jerry
Sep 22, 2019 at 10:44 PM
FOXDEN
  • 22 POSTS
Speed sensor looks good. Gear shows no wear to speak of. Wiring looks good as well.
Sep 23, 2019 at 1:15 AM
  • 110,248 POSTS
Welcome back:
Confirm that the neutral / park switch (AKA transmission indicator switch isn't damaged, not properly connected, and there are no wiring issues. I attached a pic of the switch I'm referring to.
Let me know. It has to be something electrical if there wasn't an issue prior.
Sep 23, 2019 at 1:01 PM
FOXDEN
  • 22 POSTS
Here is pic of switch I checked out. Hope it is was the correct one. No wiring damage I can see. The connection was on tight. The switch
Does not have a damage and appears to work correctly.
Sep 23, 2019 at 9:21 PM
  • 110,248 POSTS
Does the gear indicator react properly? In other words, does it indicate the correct gear all the time?
Sep 24, 2019 at 10:03 AM
JBFOX
  • 7 POSTS
Yes. The indicator in the instrument panel reads correctly when you change the gears with the stick .
Sep 24, 2019 at 11:19 AM
  • 110,248 POSTS
The only thing I can think of then is line pressure. Are you certain that the cooling lines were not partially bent or damaged in anyway that could cause a restriction?
Sep 24, 2019 at 11:59 AM
JBFOX
  • 7 POSTS
Checked the lines, they are in good shape. Do you think since the cars sat for 2 years some of the seals inside the transmission could have gone bad?
FOXDEN
Sep 24, 2019 at 9:24 PM
  • 110,248 POSTS
Welcome back:
It could be anything, but I suspect it is either an electrical component or something is blocking pressure. Have you pulled the pan to see the condition of the fluid and filter? Something could be partially blocking it. From sitting, maybe enough dirt has dropped into the pan.
Okay, I do have a question that you may find stupid, but are the front axles full inserted into the transaxle? If the transmission was good before you stopped driving it, I doubt it just went bad. I suspect it's something simple.
Sep 25, 2019 at 10:12 AM
JBFOX
  • 7 POSTS
Pulled the pan, fluid looked good, filter was in good shape. Bottom of pan, clean.
Axles are in all the way.
FOXDEN
Sep 25, 2019 at 1:26 PM
  • 110,248 POSTS
Welcome back:
The only thing we have left to check is line pressure. If that is good, either you have something stuck in the valve body or there is an issue with the ECM. The ECM does control the transmission on this vehicle.
If you want directions for testing line pressure, let me know. It will require a scanner which can read these types of codes. Here are the directions and specs are in the pics below.
Hydraulic Tests
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Testing and Inspection Component Tests and General Diagnostics Hydraulic Tests
HYDRAULIC TESTS
HYDRAULIC TEST
Measure the line pressure.
NOTE:
- Do the test at normal operation fluid temperature 50 - 80 °C (122 - 176 °F)
- The line pressure test should always be carried out in pairs. One technician should observe the conditions of wheels or wheel stoppers outside the vehicle while the other is doing the test.
- Be careful to prevent SST's hose from interfering with the exhaust pipe.
1. Warm up the ATF.
2. Remove the test plug on the transaxle case front left side and connect SST.
SST 09992-00095 (09992-00231, 09992-00271)
3. Fully apply the parking brake and chock the 4 wheels.
4. Connect an OBD II scan tool or TOYOTA hand-held tester to DLC3.
5. Start the engine and check idling speed.
6. Keep your left foot pressed firmly on the brake pedal and shift into D position.
7. Measure the line pressure when the engine is idling.
8. Depress the accelerator pedal all the way down. Quickly read the highest line pressure when engine speed reaches stall speed.
9. In the same manner, do the test in R position.
pic 1
Specified line pressure:
If the measured pressure is not up to specified value, recheck the throttle cable adjustment and retest.
pic 2
Sep 26, 2019 at 12:15 PM
JBFOX
  • 7 POSTS
Thank you for your help. We taught me many things to look at.
My son found a used transmission for $150.00 and we put it in and all seems well with it.
I do have a problem with a different vehicle and will start a new conversation for that one.
Oct 10, 2019 at 10:52 PM
  • 110,248 POSTS
Welcome back:
I'm glad you got it going. Let us know if you have questions in the future.
Oct 11, 2019 at 1:40 PM
