What other transmissions would fit my truck?
215,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
YNOTMOOR
What transmissions fit my truck?
Feb 11, 2024 at 7:38 AM
  • 110,248 POSTS
There were a couple of different transmissions that were options. The most common one is the 42RE which is a 4-speed automatic. If that is what you have, you should be able to go a couple of years back or forward from 2001 and it should work.
The only real concern when you change model years is whether the sensors/connectors remain the same. As far as the transmission itself is concerned, it is basically the same.
Note, I believe the same transmission was used in the 2wd Durangos as well.
Let me know if this helps.
Feb 11, 2024 at 1:09 PM
YNOTMOOR
Is the 42RE transmission the same as A500 ?
Feb 12, 2024 at 7:43 AM
  • 110,248 POSTS
Yep. One in the same. See pic below.
Feb 12, 2024 at 7:47 AM
