transmission
50,300 MILES
HITHERAZZ
I have a 90 chevy caviler 5 speed 2.2 motor fwd car was running now the shifting is messed up rev. is forward and neutral is forward when the clutch is out if I hold clutch in car stays shifter cables are good to was low on fluid but filled now how do I get it back to normal
May 15, 2013 at 5:34 AM
you have a cable issue. you need a shop to look at the shifting controls to see where the failure is
May 15, 2013 at 11:46 AM
HITHERAZZ
cables are new
May 16, 2013 at 12:54 AM
