When accelerating transmission locks down in first gear
150,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DHBOBCAT
start going, and when it shifts it locks down in 1st.
Jun 1, 2020 at 10:22 AM
Good morning,
What do you mean it locks down in first gear? Do you mean it will not up-shift?
How long since you had the fluid and filter changed?
Is the check engine light on? The throttle position sensor is a primary sensor for shifting times for the transmission.
Jun 1, 2020 at 9:14 PM
