My reverse gear works, but when i put it in drive it does not move what could be the problem?
Aug 21, 2016 at 2:33 AM
JERMAINE STEWART
MEMBER
My email adress is Stewartjermaine45@gmail.com
Aug 21, 2016 at 2:35 AM
SATURNTECH9
✓Experienced Mechanic
Has the transmission fluid ever been changed? It is supposed to be changed every 50,000 miles.The first thing I would do is check for codes and then check the transmission pressure.You could have a internal failure inside the transmission.
