Possible transmission or differential issue
104,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
WILLT1963
  • 9 POSTS
62TE 6spd transmission. At a light went to accelerate and wham, felt like hitting a curb. Able to drive to side of road. Suspect transmission blew up, it is a sealed only "service tech" check type. Been really dragging my feet on this one so plenty of time to think. Seems the motor mounts are both broken. Car starts but tons of noise and will not shift into any gear or that's what it seems like. pulled axles and started the process of removing the transmission. A person who is listening to my description (council of motorheads at work) thinks it is possible that it is the differential that is what is broken and not the transmission. the differential gear pack hangs off the back, so I have to remove the tranny to service it anyhow. Do you think it is plausible it could be the ring gear or the differential gears in the carrier? Where do I get a replacement? Is this a problem: the differential blowing up separately and not the transmission?
Oct 8, 2021 at 12:23 AM
  • 110,251 POSTS
It is very possible. Tell me, when you place it in gear, does the speedometer indicate a speed but the vehicle doesn't move?
Oct 8, 2021 at 11:15 AM
WILLT1963
  • 9 POSTS
Never goes into gear. And I do not remember if the speedometer moved while we towed it home.
Oct 10, 2021 at 9:35 AM
  • 110,251 POSTS
When you place it in drive and have no reaction, rev the engine slightly and see if the speedo moves. If the differential is the issue, the speedo will still work.
Oct 10, 2021 at 1:01 PM
WILLT1963
  • 9 POSTS
Makes sense. Will keep you updated.
Oct 11, 2021 at 12:05 AM
  • 110,251 POSTS
Sounds like a plan. Let me know what you find.
Oct 11, 2021 at 1:27 PM
