Transmission not shifting into first gear
135,000 MILES • 4 CYL • 2WD • MANUAL
WESLEY LUNDBERG
Can’t put it in first gear.
Jun 28, 2020 at 8:20 AM
Does it shift into all the gears except first?
Will it go into 1st with the engine off?
This could be a bad synchronizer in the transmission.
I attached a picture for you of the assembly. If that is the issue, then the transmission will need to be removed and broken down.
Jun 29, 2020 at 8:02 AM
  • 55,746 POSTS
This is typical when the clutch has fallen apart and it wont disengage. I assume you cant put it in any gear correct? This video will help explain with instructions on how to change the clutch out:
https://youtu.be/EpBMj5ZY_bo
This video shows the job being done on a similar car, the process is the same:
https://youtu.be/6N6b5F2ChyE
Jun 29, 2020 at 9:41 AM
