transmission is not shifting into fifth gear
180,000 MILES • 2.5L • V6 • FWD • MANUAL
DANNY G
Car will not shift into fifth gear. I need to know what type of transmission is in the vehicle and what the issue could be? thank you.
Feb 4, 2017 at 6:55 AM
HMAC300
  • 48,601 POSTS
if it will not shift into one gear it is either a broken pin inside transmission for shifting, a bad synchro, or worn out shift fork. anyone of three items plus a worn shift ball can cause your problem so it has to go apart. you have a type "G" transmission.
Feb 5, 2017 at 1:04 AM
