Transmission not shifting properly
1994 MAZDA MPV
140,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
CHRISTOPHER PERRY
Transmission goes into drive and reverse no problem but when driving it will not shift into any high gears. where should I start to look for to try to get it out of limp mode?
Sep 15, 2021 at 4:06 AM
  • 110,244 POSTS
If you haven't already, confirm the transmission fluid is clean and full. If it is, there could be an issue with a shift solenoid, transmission line pressure, or an electrical issue.
If the fluid is full, next check for diagnostic trouble codes. Take a look at this link. It explains how to retrieve them:
https://www.2carpros.com/articles/diagnostic-trouble-codes-for-1995-and-earlier-mazda-cars-obd1
Sep 15, 2021 at 2:06 PM
