Transmission swap
100,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
SANDERS530
  • 10 POSTS
Will a 2001 Xterra 4x4 transmission fit in a 2003 Xterra (not a 4x4 )?
Aug 20, 2019 at 9:33 AM
Good evening.
Yes, but if you want the 4 wheel drive to work, you will need the 4 wheel drive transmission.
Are you planning on keeping the 4 wheel drive?
Aug 20, 2019 at 9:52 AM
SANDERS530
  • 10 POSTS
Will a transmission out of a 2001 4wd Xterra fit in my 2003 2wd Xterra?
Aug 21, 2019 at 4:55 AM (Merged)
  • 110,248 POSTS
Welcome to 2CarPros.
They are two different style transmission. Being one is for 4wd, the housing will be different. Plus, I suspect the internal electronics will be different as well. I only recommend a direct fit part for this. Otherwise, you may end up having TCM (transmission control module) issues.
