Transmission does not shift past third gear
165,000 MILES • 2.3L • 4 CYL • AUTOMATIC
LENNYB
  • 11 POSTS
The transmission will not go further then third gear. i took solenoids out after checking with the launch. the first solenoid according to the launch is faulty. i changed the solenoid around with a good one but does the same. i am of the opinion that there could be a electrical problem and wonder if anyone can assist me anyone and explain where the wiring that connects to the solenoids comes from? i do not seem to be able to locate them for or maybe a relay or something please. thanks
Jan 31, 2018 at 2:59 PM
Good morning.
Do you have a check engine light? if you do, can you tell me the code? if it is a solenoid then a fault code will be stored.
Jan 31, 2018 at 3:31 PM
LENNYB
  • 11 POSTS
Morning.
Hi, the dash light is AT.
Jan 31, 2018 at 3:44 PM
Okay, do you have any way or reading the fault code? If I have the code, I can help narrow down the area of failure.
roy
Jan 31, 2018 at 4:09 PM
LENNYB
  • 11 POSTS
First test with launch x431 = solenoid 1 0 percent.
Then second test gear four incorrect ratio Dtc.
Jan 31, 2018 at 4:25 PM
Okay, incorrect gear ratio indicates slippage internally in the transmission. that is a mechanical issue inside the transmission.
Jan 31, 2018 at 6:27 PM
LENNYB
  • 11 POSTS
Okay.
Jan 31, 2018 at 6:30 PM
LENNYB
  • 11 POSTS
Thanks, i am busy with the TMC box, but will keep you updated.
Jan 31, 2018 at 6:31 PM
Great, we will be here.
Jan 31, 2018 at 7:04 PM
LENNYB
  • 11 POSTS
Thanks.
Jan 31, 2018 at 7:08 PM
Anytime.
Jan 31, 2018 at 7:09 PM
