Transmission is engaged in forward gear it won't switch out
270,000 MILES • 3.0L • 6 CYL
KEND.KD75
  • 21 POSTS
Transmission is engaged in forward gear it won't switch out. lever on Transmission is moving.
Mar 25, 2019 at 5:31 AM
Good evening,
Is the check engine light on? The throttle position sensor controls the shift points of the transmission.
How long since you changed the fluid and filter?
May 4, 2021 at 3:07 AM
KEND.KD75
  • 21 POSTS
On the cooler lines the line from the top of the radiator goes to the top on the transmission or the bottom hole on the transmission?
Top of the transmission.
KEND.KD75
  • 21 POSTS
would switching those two lines on the transmission make any difference?
No, it will not make any difference.
