Transmission not working properly
250,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
SB1245
When i put my car in reverse and hit the gas, it revs up but doesn't move. When i put it in neutral, it's like its in drive. Drive works fine.
Jul 10, 2021 at 2:13 AM
Good afternoon,
When the transmission is in the park, does the car try to move? It may try to go backward.
If it does, it could be the transmission shift cable out of adjustment or just worn out. I posted below 2 youtube videos of the replacement of the shift cable.
https://www.youtube.com/watch?v=dP8Zjbc3SbE
https://www.youtube.com/watch?v=GHiMQLcITuo
Jul 10, 2021 at 6:30 AM
SB1245
When the transmission is in park, it does not try to move. When you put it in reverse, it doesn't move the engine just revs. When you out it in drive or neutral, it will move.
Jul 10, 2021 at 7:54 AM
Then it is an internal failure in the transmission not allowing reverse.
You will most likely either need a rebuild or replace it with a used transmission.
Jul 10, 2021 at 8:21 AM
