Transmission, code 633
167,000 MILES • 7.5L • V8 • 4WD • AUTOMATIC
BULLHORN
truck has 633 code.
Jan 5, 2020 at 11:39 AM
Good morning,
If you did a key on engine off test and the 4 wheel switch was in 4 wheel drive, that would set the code.
Redo the test with the switch in 2 wheel drive and see if the code is still present.
Jan 5, 2020 at 7:18 PM
