Transmission staying in drive
140,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
STARLORD1976
  • 173 POSTS
I put all new solenoids in for transmission. And the car is doing same thing it’s just staying in drive. Is there anything I have to do for them to start working?
Sep 8, 2019 at 3:29 AM
  • 110,248 POSTS
Welcome to 2CarPros.
When you say it only stays in drive, when it is in park or reverse, does it feel like the transmission is fighting itself? If it is in neutral, does it still move?
As far as a relearn, there isn't one. Also, I assume the shift linkage is properly attached.
Sep 8, 2019 at 12:50 PM
STARLORD1976
  • 173 POSTS
When I put it in drive it doesn’t hit first and second it just stays and stays in drive, but if I change gears manually they all work.
Sep 8, 2019 at 2:16 PM
  • 110,248 POSTS
Welcome back:
Is the check engine light on? Is the trans fluid clean and full?
Sep 9, 2019 at 10:43 AM
