Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Drivetrain
Transmission
Symptoms
Not Shifting
Transmission not shifting properly
1999 FORD EXPLORER
248,000 MILES • 3.2L • V8 • 4WD • AUTOMATIC
AMBER STOLL
MEMBER
1 POST
When I'm driving my vehicle acts like it's stuck between gears not wanting to change into right gear.
Aug 26, 2019 at 1:50 AM
Experienced Mechanic
Good afternoon,
Does the engine run away from the transmission?
Is the check engine light come on?
When was the last time you had the fluid and filter changed?
Aug 26, 2019 at 6:14 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
