Transmission
17,800 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
MITSUBISHI GALANT
Transmission solenoid replacement.
Jan 6, 2017 at 4:48 AM
DOCFIXIT
  • 18,828 POSTS
Inside transaxle the ELC contains two shift solenoids this is not a DIY repair. What is problem with transmission? Please explain in detail.
Jan 6, 2017 at 6:13 AM
MITSUBISHI GALANT
Where the transmission solenoid snaps into the transmission well plastic broke so the transmission oil was pouring out.
Jan 6, 2017 at 9:05 AM
DOCFIXIT
  • 18,828 POSTS
Ouch! the valve body will need to be replaced if you can find one. The plug and wiring are integral with valve body and is not serviceable. Maybe salvage yard.
Jan 7, 2017 at 2:58 AM
