Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
CJ5
Drivetrain
Transmission
Reverse
transmission
1980 JEEP CJ5
125,000 MILES • 2.1L • 6 CYL • 4WD • MANUAL
JAGA5
MEMBER
i was driving around fine but, when i got home i only had second gear, neutral, and reverse. in neutral i also had reverse.
Oct 28, 2017 at 7:32 AM
CJ MEDEVAC
Experienced Mechanic
SR-4 or T-176? (4 speeds)
Is this Jeep stock?
Can you explain the situation a little better than in your initial question?
Do you drive like Grandma (like me) or are you really hard on your Jeep?
Run thru the gears sitting still (1, 2, 3, 4, R) Explain how they feel as you enter and exit each one. (or will it even go into positions?)
The Medic
Images (Click to enlarge)
Oct 30, 2017 at 8:01 AM
Add image or video
Ask a new question
Engine won't start
Ignition — No Spark
