Transmission slipping and now car will not move
111,293 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
KAYLA N CODY DUNCAN
Was driving down the highway when the car acted like it was knocked out of gear or slipped into neutral. Now the car will not move. I have already checked the linkage and the brake switch.
Jan 2, 2021 at 5:54 AM
This could be a couple things but it clearly sounds like a possible pump issue or other internal transmission issue. So that means we need to start with checking for codes and going from there.
Also, here is a guide that will help with some general issues which may apply here:
Once we know what codes are in there, we will have a better idea as to what the issue is. Thanks
Jan 3, 2021 at 8:37 AM
