transmission
MGOOD2
when I shift into gear it doesnot respond then it does is doesn't smell burnt its clean but it will grab second you case it shift into gear but not moveif I shift threw the gears a litte to each one some time it grabs the gear and then dont
May 11, 2013 at 1:53 PM
  • 31,937 POSTS
Auto problems like this are not something that you can fix at home, this sounds like an internal failure possibly a shift solenoid or a pressure problem, this should be checked out by a trained auto tech it will have to be tested with specialist equipment first hand.
May 11, 2013 at 4:24 PM
