Transmission
MGOOD2
  • 1996 FORD WINDSTAR
When I shift into gear it doesnot respond then it does is doesn't smell burnt its clean but it will grab second you case it shift into gear but not moveif I shift threw the gears a litte to each one some time it grabs the gear and then dont
Saturday, May 11th, 2013 AT 8:53 PM
  • 31,937 POSTS
Auto problems like this are not something that you can fix at home, this sounds like an internal failure possibly a shift solenoid or a pressure problem, this should be checked out by a trained auto tech it will have to be tested with specialist equipment first hand.
Saturday, May 11th, 2013 AT 11:24 PM
