transmission
1990 FORD BRONCO
67,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
DHRACER6061
  • 49 POSTS
When driving if I speed up or go under load the trans shifts and shudders for a couple seconds until I let off and give more throttle.I was told by a fourm it sounds like torque converter shudder The trans is an e40d will a shift improver kit and filter fluid change help or fix this. There is no slip and all gears work fine except the shudder at low rpms
Jan 23, 2016 at 9:40 AM
DHRACER6061
  • 49 POSTS
And shifts are very lazy
Jan 23, 2016 at 10:17 AM
  • 31,937 POSTS
Start with a service and inspect the pan for signs of clutch linings, also i would get the car to a transmission workshop and get the line pressures checked start here.
Jan 23, 2016 at 11:59 AM
DHRACER6061
  • 49 POSTS
Ok do you know the average price to get pressures checked
Jan 23, 2016 at 1:03 PM
  • 31,937 POSTS
you would be looking at 1 hr labour therabouts so as your local work shop their price.
Jan 23, 2016 at 6:45 PM
