Transmission "AT" on dashboard?
137,000 MILES • 2.5L • 4 CYL • AUTOMATIC
TEMYNATOR XT
Since my vehicle listed above s hatchback been down for a while, so I turn it on so the battery won't die, then one day I leave it running for a good hour or so with the heater on so the bugs won't get in and then the next day the transmission started to kicks off and not shifting as it should, so I then see the "AT" on the dashboard!
After a few days, turning it on the "AT" on the dashboard was gone and I was like, "sweet! I fixed it lol!!" so was able to drive it like normal and then it came back!
Sometimes after running for a long time the "AT" on the dashboard goes away, so I figured that it should be the transmission sensors.
I just don't know where the sensors are located and should I get them at the dealership or just online, according to mechanic Scotty says that those sensors are pretty complex, and you are better getting them at the dealership of your car.
What do you think about this situation?
Thanks in advance!
Sep 4, 2024 at 1:19 PM
  • 55,781 POSTS
It does sound like the turbine or intermediate shaft sensor might be bad, but we should run the codes to see which ones are stored, even though the light is off there can be codes still.
Here is the location of the turbine and intermediate speed sensor so you can check the electrical connector for corrosion and if a code is present for it swap it out. The sensor can be weak and cause an issue as well. Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Sep 5, 2024 at 2:01 AM
