Transmission locks up in reverse
390,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
ROBERT KLEIMANN
Rear end is good went through it.
Mar 12, 2020 at 8:33 AM
  • 110,248 POSTS
Any noise from the transmission? Also, any noise when it locks? If you press the throttle, is the engine loaded? Have you tried to remove the driveshaft to see if it still locks when pushing backwards indicating a possible brake issue? Are the u-joints in good condition?
https://www.2carpros.com/articles/how-u-joints-work
Mar 12, 2020 at 10:17 AM
