Engine cranks but does not start after replacing the transmission
2003 LINCOLN LS
194,000 MILES • 3.9L • V8 • 2WD • AUTOMATIC
SHELBS
  • 8 POSTS
I replaced the transmission and now it cranks but wont start. Could you please tell me what happened? It ran just fine before the repair.
Mar 8, 2021 at 6:16 AM
More then likely you have a connector that is not installed correctly or left off.
Here is a guide that will help with these issues but I suspect you will find the issue by running over all the connectors that you took off and make sure they are connected properly.
https://youtu.be/dCjmRL3p4Cs
Next we can scan for codes and find out what codes are there just to find out what we may have that shows us what the cause is.
Let's start with this and go from there. Thanks
Mar 9, 2021 at 7:45 AM
