I replaced the transmission and now it cranks but wont start. Could you please tell me what happened? It ran just fine before the repair.
Mar 8, 2021 at 6:16 AM
✓Experienced Mechanic
More then likely you have a connector that is not installed correctly or left off.
Here is a guide that will help with these issues but I suspect you will find the issue by running over all the connectors that you took off and make sure they are connected properly.
