Transmission
197,000 MILES • 3.5L • V6 • AWD • AUTOMATIC
DUSTINMORGAN5617
  • 5 POSTS
When it is time to shift i have to let off the gas to get it to shift. It also has a slap shift. Could i use the slap shifter instead of letting it shift its self
May 2, 2016 at 12:11 AM
HMAC300
  • 48,601 POSTS
you can but get it scanned for codes first there may be another problem
May 2, 2016 at 2:28 AM
DUSTINMORGAN5617
  • 5 POSTS
I had it checked for codes and 0 codes. If the car has been sitting for almost a year could old fluid make it not shift right
May 3, 2016 at 7:33 AM
HMAC300
  • 48,601 POSTS
old fluid in a trans in ayear doesn't really mean a lot as far making stuff shift etc.check fluid level and for color if you can, if dark brown or black then go to a trans shop. Or you could try a fluid change if you liked. then drive it for about a couple of weeks and see if it straightens out it may. if not have a trans guy look at it.
May 3, 2016 at 7:56 AM
