Transmission
62,500 MILES • 2.4L • 4 CYL • AUTOMATIC
WALTERBANKS34
  • 5 POSTS
I was driving 2 weeks ago an drhe car stopped accelerating and just started revving up so I put the car in park and it made this crazy grinding noise until I turned it off. With the car in park it will roll if on a hill but will hold with break engaged. Automatic transmission
Jan 25, 2019 at 1:05 AM
Good afternoon
This sounds like you have a bad axle shaft in the front of the car.
https://www.2carpros.com/articles/replace-cv-axle
I would jack it up and inspect the axles and see if one or both have failed and are not connected to the tires.
Jan 25, 2019 at 1:28 AM
WALTERBANKS34
  • 5 POSTS
Thanks Roy I have just one more question. The fact that the grinding noise only happens when the car is on and I put it in park from any other gear has nothing to do with transmission has me baffled
Jan 25, 2019 at 2:00 AM
The grinding noise is from the parking pawl trying to engage in park.
Jan 25, 2019 at 2:10 AM
WALTERBANKS34
  • 5 POSTS
Gotcha thanks
Jan 25, 2019 at 2:16 AM
Your welcome
Always glad to help
Jan 25, 2019 at 2:18 AM
WALTERBANKS34
  • 5 POSTS
Hey roy it's me again hopefully for the last time. The car acts like its stuck in neutral. It wont go in reverse either. Everyone keeps saying it sounds like a transmission problem
Jan 25, 2019 at 3:56 AM
OK, I am not everyone and if you have an axle issue it will not engage into any gear.
Get the axles checked and stop listening to people who know nothing about this issue.
Jan 25, 2019 at 4:00 AM
WALTERBANKS34
  • 5 POSTS
You're right lol
Jan 25, 2019 at 4:05 AM
Just get them checked. It is an easy repair and not that expensive.
Jan 25, 2019 at 4:07 AM
