Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-250
Drivetrain
Transmission
Interchange
Transmission swap
2004 FORD F-250
195,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
HERMAN DENNIS
MEMBER
Need to know if a transmission out of a 4.6 fit a 5.4.
Apr 15, 2019 at 10:20 AM
Experienced Mechanic
Good evening,
Do you know the model number such as 4R100 or 5R55?
They both need to be the same. They both need to be four wheel drive.
If they are both the same such as the ones above, yes.
If one is a 4r and the other is a 5R, then no.
Apr 15, 2019 at 11:05 AM
BMDOUBLE
Should fit.
Apr 16, 2019 at 12:26 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
