Transmission shifting hard?
223,000 MILES • AUTOMATIC
NICHOLAS896745
Transmission shifting hard.
Dec 12, 2024 at 4:54 PM
  • 55,711 POSTS
Can you tell us if the speedometer is working, do you have a check engine light on, have you checked the fluid level, also does the engine have good power?? I can tell you I have seen the turbine shaft speed sensor get weak and cause this issue and a clogged catalytic converter. Here is a guide so you can check the cat and the location of the sensor so you can check it out. The sensor is on the transmission case near the differential:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
and if you have a check engine light on:
Please upload pictures or videos in your response of any problems so we can see what to help you with.
Dec 13, 2024 at 9:10 AM
