no forward or reverse at all, but regained in a couple of minutes
230,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
MISSMIA
Only when starting off problem occurs. Has also caused a scenario where there has been no forward or reverse at all, but regained in a couple of minutes. Checked solenoids and they all work. also changed speed sensor still the same. Car doesn't slip in hills or under load when moving.
Oct 6, 2019 at 2:45 AM
Good morning,
I would start by changing the fluid. I may be dirty and not allowing the proper flow of fluid for application.
Oct 6, 2019 at 3:08 AM
MISSMIA
Had previously added 2 liters to transmission as fluid was blackish. No problem until 2000 km later. Had pan off to check solenoids and only a small amount of wear material present.
Oct 6, 2019 at 4:13 AM
When did you have the pan off? Black fluid is burned fluid and not good.
Oct 6, 2019 at 4:29 AM
MISSMIA
Had it off a few weeks ago when I took the solenoids out to check them. There's still a bit of reddish color when on a paper towel but mostly black. Does not smell burnt. I would say it was never changed. I bought it off a guy a few months ago, was working perfect.
Oct 6, 2019 at 5:09 AM
You need to start there. I would change it again.
Oct 6, 2019 at 5:18 AM
MISSMIA
Okay, will do. thanks
Oct 6, 2019 at 6:22 AM
