When accelerating from a stop there is a slight clunk in transmission
177,000 MILES • 3.8L • V6
JACKNUT
  • 65 POSTS
Sometime I get a slight clunk in gear when waiting at red light then taking off. other than that it shifts fine and no slips. fluid is clean and not burnt. I will be changing transmission screen. I need to know what the correct transmission fluid is for this car.
Dec 12, 2020 at 10:11 PM
  • 110,248 POSTS
A slight clunk could be several different things. For example, play in a CV joint, a motor mount. and so on.
A CV joint, which is part of the drive axle, can get play in them. Usually, they make a clicking sound when making a sharp turn when they are bad or going bad.
Here is a link you may find of interest:
https://www.2carpros.com/articles/how-a-cv-joint-works
Now, there could be an issue with an engine or transmission mount. If you are stopped and not moving, does it do it or is more likely to happen when you accelerate?
As far as the transmission fluid, see the attached pic.
Let me know as much as you can about the noise. Also, if it is loud enough to record with your phone, do that and upload it for me to hear.
Take care and let me know if I can help.
Dec 13, 2020 at 1:03 PM
JACKNUT
  • 65 POSTS
It's like it's not in gear then is. also, did it today like it slipped in gear while already moving.
Dec 13, 2020 at 7:09 PM
JACKNUT
  • 65 POSTS
Sometimes feels like it's in 2 gears then jumps out of one.
Dec 14, 2020 at 4:18 AM
JACKNUT
  • 65 POSTS
Dextron 3? I've been told Dextron 6. And that 6 replaces 3.
Dec 14, 2020 at 4:20 AM
  • 110,248 POSTS
The Dexron 3 was what was original in this vehicle. Dex 6 is what has replaced all the others. Thus, that is fine to use.
Based on your description, it sounds like a line pressure issue. Has the transmission ever been serviced (pan, gasket, new fluid)? I realize you plan on filter replacement, but am wondering if this is the first time.
Here are directions for servicing it. The attached pics correlate with the directions.
_________________________
2005 Buick LaCrosse V6-3.8L VIN 2
Oil Filter and Seal Replacement
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Service and Repair Removal and Replacement 4T60-E/4T65-E Automatic Transaxle On-Vehicle Service Oil Filter and Seal Replacement
OIL FILTER AND SEAL REPLACEMENT
Removal Procedure
pic 2
1. Remove the oil pan (24) and the gasket (25).
2. Remove the filter (100). Remove the lip ring seal (101) pressed into the case only if replacement is necessary.
3. Inspect the oil pan and the filter for this foreign material:
^ metal particles
^ clutch facing material
^ rubber particles
^ engine coolant
4. Determine the source of the contamination if foreign material is evident.
5. Correct the source of the contamination.
Installation Procedure
pic 3
1. If removed, install a new seal (101).
pic 4
2. Install the filter (100).
3. Install the gasket (25) and the oil pan (24).
___________________________________
Do me a favor, I have seen the filters on these vehicles get dirty enough to prevent the flow of fluid. You said the fluid is clean. Is it full and does it have a burnt odor to it?
There is also a transmission pressure switch in the trans. It may be going bad. However, that should set a diagnostic trouble code. I attached a pic below showing it's location. See pic 1.
Dec 14, 2020 at 8:14 AM
JACKNUT
  • 65 POSTS
Yes, it has been changed at least 3 times that I know of last time about 3 years ago. no it doesn't smell burnt.
Dec 14, 2020 at 5:41 PM
  • 110,248 POSTS
Then we need to start checking other things. Here is a link that shows how to check different suspension and steering components that can cause a clunk or popping noises. Take a look through it and see if anything helps.
https://www.2carpros.com/articles/popping-noise
Dec 15, 2020 at 9:23 AM
