Transmission
221,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
ALEESAROSE68
My car will go into reverse but not drive forward unless the transmission is unplugged. i have already replaced all solenoids and filter has been replaced along with putting new fluid into it. So i am clueless on what the problem could be?
Apr 17, 2018 at 9:20 AM
Good evening.
Are there any codes stored in the transmission?
Apr 17, 2018 at 10:21 AM
ALEESAROSE68
Yes, (p1825), (p2534), (p2764), (p0717), (p0700), (p0523) .
Apr 17, 2018 at 9:37 PM
Okay.
Code P1825 item description.
Symptom/DTC P1825.
Descriptor.
Probable Causes:
Internal Mode Switch (IMS).
Traction Control Module (TCM) Switch.
Apr 17, 2018 at 9:42 PM
Code P0717.
Item Description
Symptom/DTC P0717
Descriptor
Probable Causes:
Input Shaft Machined Face for Damage or Misalignment.
Input Speed Sensor (ISS).
Input Speed Sensor (ISS) for Damage.
Input Speed Sensor (ISS) for Metallic Debris.
Input Speed Sensor (ISS) for Misalignment.
Transmission Control Module (TCM).
Transmission Control Module (TCM) Connector Pins Misalignment.
Transmission Control Module (TCM) Damaged.
Transmission Control Module (TCM) Metallic Debris.
Apr 17, 2018 at 9:43 PM
Code P0523
Item Description
Symptom/DTC P0523
Descriptor
Probable Causes:
Engine Control Module (ECM).
Engine Oil Pressure.
Engine Oil Pressure Sensor (EOP).
2534
Code P2534
Item Description
Symptom/DTC P2534
Descriptor
Probable Causes:
TRANS Fuse Open.
2764
Code P2764
Item Description
Symptom/DTC P2764
Descriptor
Probable Causes:
Torque Converter Clutch (TCC) Pulse Width Modulated (PWM) Solenoid Valve.
Apr 17, 2018 at 9:46 PM
Okay, did all this happen at once?
they all have in common the transmission control module.
it could be either wiring harness or the module itself. these all need to be checked to determine the exact failure.
Apr 17, 2018 at 9:49 PM
ALEESAROSE68
Well all i know is i got the car from a friend like this and he had got it like that and never even drove it, but i thought it would be a easy fix. so i guess to answer your question i do not really know if all happened at once. And i already replaced the control module and the solenoids so i am just kind of stuck here on this one.
Apr 18, 2018 at 12:19 AM
ALEESAROSE68
And so you think wring harness?
Apr 18, 2018 at 12:20 AM
did you have the module flashed?
yes, that would be the next step.
Apr 18, 2018 at 12:22 AM
